your question was answered a couple posts up. also one million other times on this forum.
Originally Posted by RonJR
There are certain points in the XREAS system that have check valves where you can open it with a minimal loss of fluid. I believe Toyota says you can open the system once to replace an individual shock, but the next time you will have to replace the entire system. It doesn't contain a lot of fluid, so a few drops lost compromises its performance significantly. There is no way to add fluid to the system outside the factory.
A replacement XREAS system consists of 4 shocks, dampers, check valves, and all of the interconnecting tubing shipped as a complete, closed system, and is installed as such by the dealer shop. That's why it costs upward of $2500 to replace it. Also why most people just remove it when it fails and replace it with more conventional shocks.
If you want to stay OEM, you can replace the XREAS shocks with the conventional OEM shocks for an SR5, and your Sport will now handle and ride like an SR5.
