Banned
Banned
i just took the front bumper, mud flaps and running boards off my truck last night, and wow. it now looks WAY better. im also considering throwing 31's on, as opposed to the stock 29's i have. i dont like the fact that a coil over reduces flex, so im thinking about ghetto fixing my rear leafs, by adding blocks under the leafs, and a new leaf or two. i may also weld up some longer shackles if it is necessary. do you have any spare leafs lying around that you dont need? i was thinking if i cant finding any for cheap, just add some homemade spacers in between the leafs out of 1/2" steel plate lying around the welding school i go to, with longer u bolts, or just cram a hockey puck(s) between the leafs. the leafs are totally flat, if not slightly bowed UP. so they are essentially screwed. any suggestions? would an extra leaf and some blocks and maybe some leaf spacers do the cure?
