Originally Posted by ecarpenter2
I have been thinking of doing this as well!! Do you have pictures of the outside?
I will post some pics tonight.
Originally Posted by 415T4R
I have been looking into doing this for a while now, I have an SR5 without puddle lights, do you know if this would change for me if I were to pursue it using your method?
Thank you!!
Honestly....I am not sure....but I would not be surprised that you can. Easy to find out....pop off the driverside kick panel and see if white wire is present. If so, probably double check with multimeter that voltage changes with lock/unlock functions.
Also note that the dome light also lights same as puddle lamps, so you can use this circuit instead.
Originally Posted by DosSpider
This is something I've been reading a little about as I consider what mods to start adding. Thanks for the write up. You hit on the one limitation I've come to as well, the rock lights not ramping up/down with puddles. It's definitely not critical but I'd personally like to see that ability as well.
With my setup....the rock lights come ON right as the puddle lamps begin ramping up. And the rock lights shut OFF about the time the puddle lamps have ramped down to OFF.
