Another successful clearing of lights post Torque pro and BT OBD reader install
I had picked up one of the OBDII blue tooth readers to play with the Torque App, immediately after installing it my vsc/atrc lights came on, I think ABS also flashed.
I did the gas cap and battery disconnect with no success
Then ran into the TSB, 5 minutes later the codes are gone, very easy
With the ign on, If you are looking at the OBD port, short Top Row 3rd pin from Left Side and 4th Bottom Row Pin from Right Side, do it more than 4 times...its ok
I used test lead with alligator clips, just bend a small paper clip in a V/U shape and it will stay put in the OBD port
Then follow the rest, the key is to watch for the rapid blinking of the VSC light towards the end of the procedure
