Well, it's now May 2017 and I have a birthday to celebrate. She's finally legal boys!!
I've had this 4Runner since February of 2007 and am the second owner. She had just a little over 112k on her and had just had the timing belt and water pump replaced, along with all the other ancillaries to that service.
There's been a ton of work done on her over the last two years as she approached and then passed to 200k mile marker. I took pictures along the way and will post them here as I get time to do document the maintenance and modifications. My ultimate goal was to essentially create a Highlander model 4Runner clone and with the most recent addition of the sport hood, I'm pretty much done.
Only thing really left to do is get a rear swing-out bumper on it. (done as of May 2018) Well, plus doing all the wheel bearings (rear done February 2019, have parts for fronts),
re-gearing to 4.88 (done as of July 2019),
installing lockers (done in rear only as of February 2019), maybe doing manual hubs up fr....but I digress.
I really don't have a lot of pictures of her when I first got her. Just this one after getting rear ended and smashing into the two cars in front of me. Totaled all three cars except mine
After taking the running board off (pre-lift):
Finally got her completely broken in on 10-21-2015 just after noon:
Current (June 2020):
Engine Bay (current):
Her birthdate (factory specs):
Current Specs (2/20/2020):
Mileage - ~212,200
Color and Trim
Color - Imperial Jade Mica 6Q7
Interior - Oak
Engine and Drive Train:
Engine - 3.4l V6 5VZ-FE
Transmission - A340F 4-speed automatic
Transfer Case - VF2A - J-shift
Rear Differential - Nitro 4.88 with Detroit True Trac (OEM Axle Code - A03A - aka 4.10 gears)
Front Differential - Nitro 4.88
Front Suspension:
Light Racing UCA's and Bushings with greaseable UBJs (#25460)
Radflo 2.0 Adjustable Coilovers (5CT 004 00)
Sonoran Steel S.S. Extended Brake Lines
231mm Tundra Brake Calibers/Rotors (Wearever: 19-2713, 19-2712)
Sonoran Steel Front Diff Drop Spacers
Front Sway-bar Delete
StrongFlex LCA Bushings
Rear Suspension:
95 Toyota FJZ-80 LC Coils (48131-6A570) (7.5 wrap double purple/gray/white)
Tokico HD Shocks (48531-69417J)
Sonoran Steel Adjustable Panhard Bar
Sonoran Steel Extended Bump Stop Adaptors
Daystar Bump Stops
Sonoran Steel S.S. Extended Rear Brake Line
Sonoran Steel Parking Brake Bracket
Sonoran Steel HD LCA
StrongFlex UCA Bushings
Custom Extended Removable Rear Sway Bar Links
Armor:
4xInnovations Plate Front Bumber
4xInnovations Plate Rear Bumber w/Tire Swingout
Savage Skids
Stubbs Welding HD-SKO Sliders (from Sonoran Steel)
Lotus LCA Skids
Lights:
21" CREE LED Bar
4" Hella Opitlux Angel Eye Model 2500 (in bumper)
Superbright LED 48 LED Panel Interior Lighting
Custom LED Floor Lighting
Microtuning flush mount reverse LEDs
Wheels and Tires :
Vision Turbine (TuRDed out)
Goodyear Duratrac 285/75/R16 (33's)
Full Sized Spare
Sound:
Jensen VX4025 (w/backup camera)
SPL FX4-840 4-channel 840W
Infinity PR5002is Front/PR6500cs Rear
Mods:
Rear Differential Breather Extension
B&M 70264 Transmission Cooler (Solo) w/Magnafine filter
K&N Air Filter
Intake Silencer Delete w/Custom Intake Pipe
Deck Plate
Dual Red & Yellow Top Optimas w/T-Max Charge Controller
Hidden 1100W Energizer EN-1100 Inverter w/Custom Control Panel
150 Amp PowerMax Alternator
Blue Sea 5029 100AMP Aux Fuse Panel
TRD "O" Gasket
Big "3" Wire Upgrade
Smittybilt XCR9.5 Winch
Custom SR5 Fender Flare Trim
1999 OEM Sport Hood from 2wd SR5 VIN#JT3GN86R1X012xxxx
1998 Rav4 3 Nozzle Windshield Sprayers
WeatherTech Floor Mats
Toyota Window Deflectors
JDM Smoked Altezza Tail Lights
1" Fat Pat Custom Body Lift
Sonoran Steel Rear Solid Body Mounts
Rear Window Remote Roll-up
Extended Rear Storage Compartment
COOAU 4k Dash Cam
COOAU 1080p Rear Cam
To do list:
Front wheel bearings (manual conversion?)
Setup On-board air
Add water system (filtration and holding tank)
Paint roof rack (new rack?)
Headers and exhaust
Wish List
Blower
Manual transmission conversion
Manual front hubs
