Originally Posted by TRDHybrid
Three days ago i finally found cams out of a 93 camry, tackled the project in my back yard in one day, shimmed to 5vzfe specs, and only needed to change 3 of the exhaust shims all others we're in spec. As i am sc'ed loss of low end torque is not noticeable but mid and high is deff. Noticeable increase. I have a 98 limited 178k on clock and runs just as smooth as my rx450h. I did notice im running 190 deg f now as before was 183 with a 180 stat. I prob iv had since i purchased is from 50% throttle to 90% its lime the timing is hunting but full throttle its fine, any thoughts? During the cam install i replaced the knock sensor harness. It did this hunting thing before the cams swap and before the sc was installed by me. Thoughts?
That's awesome that you did the swap. I think you're the first person to actually go through with it.
