Small update:
The steering column slip joint was really loose and causing ALOT of steering wheel play. When I pulled the steering column out to weld the slip joint it rolled off of my work bench and landed on the splines DOH!!!
Luckily the same guy I bought the steering wheel and center console from sold me the steering column and yoke from the same 4runner. The new steering column shaft was tight but I tack welded it anyway. This made a HUGE difference in the way it drives. Very nice and tight.
If you have a loose steering column you NEED to do this.
Took a few pics today with the good camera:
Now I am just waiting on parts to arrive to do some actual work!
