It lives.
Below works to press the spacer sleeve out for the big long bolt so the alt and Power Steering pump can be mounted.
Below is picture of the first fire state. Pulled EFI relay to prime oil filter till low oil pressure light went out. Then installed relay and key cycled the ignition 3 times to get fuel to the injectors. Then around 3 seconds of starter and it started. Ran it around 5 seconds.
Now to install Rad and add coolant and vac out AC system.
