Originally Posted by gamefreakgc
Probably, mine also broke. If you order just a normal antenna with the teeth you can open up the motor, pull out and remaining debris, then feed the new one in and you'll be back up and running again.
Thanks for the info... I tightly pulled on the teeth and it completely removed itself from the motor. Now I have no antenna for the time being, and need to plug the hole where the top part of the antenna shaft used to live
