Well unfortunately, I think that's just wishful thinking. Look at the wiring diagrams. There's nothing else in there that should be the deciding factor. Apparently it's disabled or just simply not a factor on 4WDs.
As I said, you don't need the specific switch to try this. All the switch does is makes contact between the two wires. You can do that by just shorting the two wires with something (shorting wire). So if
you want to look for this unicorn, go ahead. LOL. I'm going to drop it and accept it the way it is. If you find something, let
us know.
Now to figure out what the other two connectors are for under the dash...
Originally posted by blk05runner
I'm sure it does but is more then just adding the switch. There might be a fuse that needs to be plug in.
give that a try once you find it and let us know.
Vehicle: Black 2003 T4R Limited V8 4WD
Mods & Equipment: Hail Damage; Kenwood DDX573BH/ rear camera; GX470 Overhead; DC power, A/V aux jacks, & USB plug inside center console box; DAC switch relocate; Interior LED swap; Footwell LED lighting; Muth heated signal mirrors, LED tails, & Valor exhaust tip.
Support our troops!
