eimkeith
For the money, I think they are great for someone that doesn't have access to a brake and a plasma cutter. The spindle gussets needed some grinding to fit properly but other than that they fit well. Same with the Shock Tower Gussets. They needed just a small amount of grinding to fit tightly. The cam tab gussets fit perfectly with no issues other than the tabs having a little bit of surface rust on them, that needed to be wire wheeled off. I'd say do it! Might want to check your motor mounts while your at it too since the shock tower gussets will make a motor mount swap a little more difficult since they block the way from the wheel well. Overall the parts are all pretty simple but wouldn't be worth much time to make since the parts are already priced pretty well in my opinion. I had a buddy that made his own gussets but he had access to a full fab shop, even then I probably would by them since they are pretty cheap and my time is worth more than making these little parts.
Spindle gusset fitment
You can see where I had to grind for proper fitment.
They welded up nicely.
Shock tower gussets
Cam Tab Gussets
