Originally Posted by AssBurns
From the site is says Fuel System Compatibility: Carburetor Not sure how much difference there is between the EFI and Carb tanks. Care to infom me the differences?
A fuel injection tank typically has the fuel pump in it whereas a Carb typically has a mechanical pump on the engine. A fuel injection pump pushes the fuel, usually somewhere from 45-65 PSI. A carb fuel pump is 4-7 PSI. A fuel injection tank will typically have a return line depending on the fuel injection setup. Carb engines typically do not. Hope this helps.
