This will be the place to see what trails my rig has been doing lately. It will also be a place to just shoot the shit. Got something to say? Say it. I'm not easy to offend and a lot of you guys are actually enjoyable to chat with. Which is saying a lot since I don't like most folks. lol
I started building my rig about 14 months ago. There was a plan for it since day one. That plan was a simple one. To make it capable of taking me where I wanted to go and also be able to get me home. This rig also does double duty as my wives daily so I had to keep it completely road worthy as well.
I'm horrible about taking photo's so I never went the build thread route. Instead I put my content all over the "What did you do in" thread. For those of you wanting to see some of the mods that got done search my username in that thread.
Thanks for stopping by.
The Rig
1997 SR5 4X4 Auto
Lift
Eibach #620 lb Springs w/ Taco Billies 2nd Perch Front
ARB OME 2861's w/Toytec Boss Shocks Rear
SPC Upper Control Arms
Extended SS Brake Lines F/R
Extended Rear Sway Bar Links
Front Sway Bar Removed
Drive Line
ARB Lockers F/R
5.29 gears
MB Motoring 352's 17x9 -12 Offset
Nitto Ridge Grappler 295/70/r17
1.25" Hub-Centric Wheel Spacers
231mm Power Stop KC2324 TBU
Armor
Relentless Fab Predator Front Bumper
Savage Off-Road Dual Swing Out Rear Bumper w/ Tire Carrier, Hi-lift Mount(soon), Rotopax mounts
Savage Off-Road Skids
Stubbs HD-SKO Sliders
Rola Roof Rack w/Custom Low Pro Mounts
Recovery
Engo 12000lb Winch Synthetic w/Wireless
48" Hi-lift
MAXSA Traction Boards
4 Gallon Rotopax Gas
2 Thirty Foot 20000lb Straps
Tools to Fix Shit On The Trail
ARB CKMA12 Mounted Under Hood
Electrical
All Grounds Over-Sized
100A Relay Wired to Ignition
100A Bussman Circuit Breaker
12 Gang w/Negative Blue Sea Fuse Box
5 40A Relays w/Custom Acrylic Mount
Blue Sea 9003E 350A Battery Disconnect(for winch)
Custom Acrylic Rocker Switch Dash Insert
2 Seven Inch Combo LED's Top of Bumper
2 Four Inch Spot LED's in Bumper
SNAN 300W Inverter
7" Electric Trans Cooler Fan
Music
Butyl and Mat Sound Deadening 75% of Rig
Pioneer TS-W259S4 Champion Series 10" Single 4ohm 1200 Watts Mounter in Rear Storage Compartment
Polk DB651's 6.5" in Rear Door
Infinity Reference 6500CX 6-1/2" w/Tweeters in Front Door
Boss AR1500M ARMOR 1500W Mono for Sub Mounted in Rear Quarter Panel Behind Sub
Hifonics ZRX1016.4 Zeus 1000W 4-Channel for 6.5" Under Drivers Seat
Dual DV526BT Double-DIN DVD Receiver
If It's To Loud Your To Old
Other Mods
Hayden Trans Cooler In-Line w/ New Rad
Auto-Meter Trans Temp Gauge w/Pillar Mount
Sonora Steel Rear Poly Body Mounts
Sonora Steel Washer Bottle Relocate
Rear Diff Breather
Front Diff Breather
June 9th 2016
Current
