Originally Posted by TotalAutomotiveLV
Our Customer Support Team was working on this earlier today...
All 17" wheels are 30lbs.
All 20" wheels are 38lbs.
_
Thanks for the info. That's heavier than some rims (SCS for example) without the beadlock.
Now reading more closely I see the 4.5" setback is for a 5 on 5.5" lug pattern, which doesn't fit the T4R Trail Edition. The 6 on 135 mm or 6 on 5.5 is the close to the T4R. 5.5" = 134.7 mm. I think the 5.5 circle is closest to the Toyota. Does anyone know if that's correct? Is 135 mm close enough? What is the stock circle?
The 5" and 4.75" backspace fit these later two wheels. The 6x5.5 is available with a 4.75" backspace.
At 4.75" backspace the center of the wheel is over the mounting surface (hub?). I'm looking at upgrading to a 285/70/17 LT Cooper or Falken. an 8.5" wheel is recommended for that size tire.
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
