Originally Posted by octanejunkie
The best place for the SGII I've seen is right on top of the steering column in front of the gauge cluster - you're not missing much there except a few idiot lights. Anything else will have you looking away from the road, unless you go dashtop.
Your choices of monitors are reasonable, I use TorquePro and have those temps plus MAF, Fuel Trims, Load and Timing on display as well as RPM so I can get a single-screen view of how hard my engine is working in a glance.
Average fuel economy is a balancing act I've not yet learned to accurately tune, so I ditched it. I've done enough driving to have an idea of my overall fuel economy which is 14-17 in the city/daily driving and 18-22 HWY driving out to NV. YMMV
My vanity plate took 15 weeks. You should have yours by Easter. Thanks Gov Brown.
I imagine once I understand what the fuel efficiency is in various scenarios I'll opt for a different metric. Yanking it out of my MINI after my next meeting (work from home)...
I'll try it on top of the column first, as you described Mike. I did indeed see a few different mounting locations in various threads... That one seems to make the most sense.
I'll be wanting to mount a mobile ham radio (Kenwood TMV71A) at some point, and I'm thinking of removing the factory radio, going single DIN to free-up a space for that unit. It has a detachable face, so there might be some creative options:
https://www.hamradio.com/detail.cfm?pid=H0-008951
Hey, is there a brightness adjust on the automatic climate control? The dash knob that adjusts such display lighting doesn't impact that unit. Does the stereo though, so I would think that it should do the automatic climate control, so maybe a loose connection...
Oh, I found a thread on the PCV location to use Seafoam (first post, photos):
You've been doing it wrong. Seafoam injection port
Toward the end, some apparently are using a Seafoam spray at the TB though...
