Originally Posted by octanejunkie
I got an aftermarket Throttle Body gasket that was more like traditional cardboard gasket material without the D shape. Mine was from some Toyota parts house/performance site, I forget the name, I think it was $20 shipped.
You'll need an IAC housing gasket too, Federal Mogul PN 61087, those deform after so many years and won't fit back into the channel once exhumed. I replaced my IAC with an eBay special, and it came with a new gasket, that was like $35 shipped and was well worth it. It's been over 14 months since I installed it and so far so good.
That IAC housing gasket seems to be the one I referenced for about 4 bucks, at least from Cambelback, part number 22215-62180:
https://partsfactory.camelbacktoyota...ket-2221562180
A new IAC is a thought, considering the price, but $4 for the gasket is likely what I'll do. Calling Camelback in a bit to see if they can add it to my order (radiator, cap, hoses, t-stat...).
On the TB gasket, I'll try to find a paper one like you referenced...
Thanks much and I hope the thrust washer gets the clearance you need for your Aussie Locker install.
