Originally Posted by TampaBay_4Runner
These tires have caught my eye once my Firestone Destination's start nearing the end of their lifespan. I'm not sure which size to go with to avoid severe rubbing issues. I have a Limited so the wheels are 18" and I do have a lift (Bilstein 5100's all around set at 0 with Wheelers T12 and T1 springs).
I'd like to bump the tire up to 285 if possible but I also don't want to deal with rubbing and chopping up fender liners etc. Is it possible to move up to 285's or should I just stick with 265/65/18?
You will need to trim, especially since these run a little larger than most 285s
Worth IMO, but it will need to be done. Your alignment (caster numbers) will play a big role in how much is needed. More positive caster helps
I'm at 5.8°, chopped the body mount, aftermarket bumper etc and still rub occasionally up front
