Originally Posted by NinjaOne
You will need to trim, especially since these run a little larger than most 285s
Worth IMO, but it will need to be done. Your alignment (caster numbers) will play a big role in how much is needed. More positive caster helps
I'm at 5.8°, chopped the body mount, aftermarket bumper etc and still rub occasionally up front
Very good info, thanks! I guess trimming wouldn't be the worst thing but I don't feel comfortable nor do I know anyone that could do a body mount chop for me if I needed that. I do have some positive caster after the alignment post-lift so that sounds beneficial. Thanks again
