Originally Posted by Dezerts10
Where would the best place to put it be? Crawling under it the lines to the cooler have fittings I think I could adapt a sending unit to but what line is the line that would tell me the most accurate temp of the atf? Or is it better to put measure temp off the fluid in the pan?
I think it would be a lot easier to put it on one of the cooler lines instead of in the pan. That's what most folks tend to do.
Personally, I would put it on the line that has fluid being sent TO the cooler. This will tell you what temperature the fluid is in the transmission, rather than what it is after it passes through the cooler.
