Originally Posted by lmturne1
Your issue won't be mounting one, rather supplying the necessary power to the unit that has a significant amp draw so far from the battery. I know the ARB harness is ~6ft, but from the cargo area, you'll need at least double that and a larger gauge wire to compensate for the additional distance.
Final thoughts: Mount in the engine bay, or prepare to work for it.
So that’s a big beefy ARB, but what about a smaller portable? Are those pretty amp hungry? Sorry I’m decently savvy with electrical stuff, but the technical aspects of it - amp draw, understanding when you’ll need higher gauge wire, what gauge you’ll need, etc - are a bit beyond my understanding. I figured if a compressor has 10 awg wire on its leads, you could extend that ~10 feet with the same gauge wire.
