If you have time, mind taking a photo with a top view?
Also, how stiff or strong are the cross bars? Do they flex when adding weight to it? An example would be securing a cooler or camping equipment. Does the cross bars flex when cinching down with ratchet straps.
Thanks.
Originally Posted by Louisiana Overland
The rack is flat but also follows the contour of the roof. It comes standard with 8 crossbars. The rear bar is 2" I think...to clear the antenna. The rest are 3" wide and they are extruded aluminum with t-slots that accept a 5/16" carriage bolt. SSO included some carriage bolts with the kit. 8 Bars will leave the area over the sunroof empty. I ordered extra bars to cover the sunroof in case I ever need to fully load the rack, and am still awaiting delivery on the extra bars. There is some added noise, but nothing obnoxious...minimal in fact. The wind fairing has a weather/wind seal at the bottom to prevent wind from sneaking between it and the roof.
