I like the sliding tray...with modifications.
The tie down item mention can be rectified with eye bolts. There are already holes in the front edge of the tray for up to 4 bolts if you want to add them for tying.
I don't like that the entire floor doesn't move, i'm working on adding a metal tray to the end of the slide, so when you pull the slide out, everything comes out and it uncovers the cubby.
And i believe it would be a much better option if a shelf was available for the back. I strap my fridge to the slider and have been experiementing with a a few different shelf ideas which will go above the fridge (about level with the rear seat back) for light items. They've worked great so far, always improving.
2016 Trail and half of an early 90s Ford Ranger
