Originally Posted by seattlee
I have a 1996 Limited that I bought about 6 weeks ago. The rear/back/tailgate window won't move when I press the switch. I've searched the threads, but still don't have a solution.
It is NOT the window lock (I pushed the button on driver's side door)
The window motor works (I pulled it out and applied 12V and it turned smoothly)
It is not the switch up front on the center console (tested the contacts per the Haynes manual)
The key switch in tailgate does NOT work. (tried it, but it doesn't do anything either)
All of the fuses look good.
I also put a voltmeter on the connection to the motor and had my dad flip the switch in the cab and there was no electrical change.
This leads me to believe that it is a problem somewhere in the middle of the switches and the motor...perhaps a relay? control unit? I don't know of a schematic to know where a relay might be.
Any thoughts?
Damn window lock got me a few days after I bought my 4runner!
Sent from my VS988 using Tapatalk
