Originally Posted by MeefZah
I actually hope no one does an in depth install post without OP's permission. Part of what is being paid for is the research and knowledge be put into this. The instructions are really, in my mind, what you are buying. I had the stuff to make these in my garage, but i lacked the knowledge of the factory harness / ECU.
It is tapping 3 wires, most likely a ground, 12v+ constant on from the light and one going to the keyhole switch. A lot of this already documented by forummembers including hatch panel removal. If I wasn't overseas I would pop that cover off and post it.
50$ to tap one wire, again People will buy a kit for clean easy install, but this forum would be straight garbage if it wasn't for the open source sharing of information about the 4runner.
