Originally Posted by LTDSC
Yours leans into eachother like mine does. I plan to add a sheet of 1/2" under it then secure them to eachother so they dont eventually bow again.
Looks good! The slides are 90% of the drawer weight.
I also found it easier to draw the holes of the slides instead of measuring as some of the measurements didnt line up when i first tried it for the holes to make.
I accounted this to the floor not being flat under the where I removed the double decker do-dad. I plan on making a shim under just the corners near the rear seat where the two boxes meet to level them out and support the sag. I'll also be using part of that flat area on the rear of the boxes to support sleeping platform legs so I need it to be solid touching the floor there. I think adding 1/2" under the entire assembly would work too but then raises the whole thing up into precious space.
