View Single Post
Old 03-02-2018, 10:55 AM
blackoutt's Avatar
blackoutt blackoutt is offline
blackoutt has a spectacular aura about blackoutt has a spectacular aura about
blackoutt's Avatar
Originally Posted by Joex481 View Post
I believe the missing dado is on the back of the top panel of the casings. I ended up having to do that one while assembling the first casing.
My drawer slide holes didn't line up either. For those still planning I would definitely recommend marking through the slides. Also, don't drill the middle holes until you have the slide mounted in the first two. Made life a lot easier for me.
Yes that's it! I thought it was a bigger piece.
Adam, looking at LH_RH_Carcass.pdf page 2 part 4 (Rear panel) there's no dimension for the height of the panel so it's assumed that it's the same height as the side panels at 10.625" but really since it's not fitting into a dado top or bottom it should be 0.25" shorter than the side panels, dimensioned at 10.375" tall. I ended up taking .125" off of it and dado'ing the back edge of the top panels for a tighter fit.
So it might not be a missing dado but it is a missing dimension for the height of the carcass rear panel that caused the slight confusion.
blackoutt is offline   Reply With QuoteReply With Quote
