Originally Posted by blackoutt
Yes that's it! I thought it was a bigger piece.
Adam, looking at LH_RH_Carcass.pdf page 2 part 4 (Rear panel) there's no dimension for the height of the panel so it's assumed that it's the same height as the side panels at 10.625" but really since it's not fitting into a dado top or bottom it should be 0.25" shorter than the side panels, dimensioned at 10.375" tall. I ended up taking .125" off of it and dado'ing the back edge of the top panels for a tighter fit.
So it might not be a missing dado but it is a missing dimension for the height of the carcass rear panel that caused the slight confusion.
i had the same issue for the tops as well.
