Originally Posted by boyguan
the airbag actually pushes the seal out and inflates that way. the handle should not affect anything. if you look at deployed bags you can see the pillar does not move.
Then as long as you make sure whatever backer that holds the bottom handle on doesn't contact the SRS airbag then it should be perfectly safe.
