Originally Posted by pwood
Just tried to do this on my 2010 SR5, and after looking at it, I'm not totally sure how the plate fits. I'm a total noob at this, but how do I even get the OEM plate off? Can't even see the bolt under there anywhere.
The TRD skid plate will fit the 2010, yes?
Mine should finally arrive tomorrow due to storms and such. Right now I dont have a front skid
If you still have your air dam you'll need to remove that.
Then remove front plastic filler piece below bumper. It's held by a few bolts and a couple large plastic plugs.
There are 4 bolts holding the skid plate, 2 in front and 2 in back. the bolts are in recessed holes.
After the bolts are removed the stock skid is held in place by 2 hooks/hangers in the front. Just pull it out from there.
The TRD skid should bolt up nicely using the same 4 bolt locations as the stock skid.
Make sure you tap the holes using the Saker-Cymon method and apply a good amount of anti seize
EDIT: I didn't tap the holes yet as I was waiting on the skid. I just tried to test fit the 10mm tap and I can confirm you will either need to drill out and tap to 10mm or use the 8mm x 1.25 tap and buy new bolts like
Kistle
stated
