This is most likely what you want.
58647 (QTY.1) | 10-UP 4RUNNER EXT TRAVEL 2.5 SERIES IR COILOVER KIT
58451DJ (QTY.1) | 03-UP 4RUNNER TUBULAR DELTA JOINT UCA KIT
52700 (QTY.1) | 07-UP FJ/03-UP 4RUNNER REAR 2" SPRING KIT
56505 (QTY.2) | 03-UP 4 RUNNER 1-3" REAR 2.0 ALUMINUM SERIES IR SHOCK
They sell that as a stage 2 kit. But you can run any rear spring and any UCA you want if you just want to order individually. I would not mess with the remote res for your use case.
