Originally Posted by Joelzy
Thank you so much for the input! I think i have almost all parts but will be replacing some most likely and that is really good to know on the clutch. Not sure what the PO ordered but there is a new clutch in the back, need to check it out.
Should i go OE on the radiator as well or something full aluminum core? that is missing completely
OEM is totally fine as far as radiators go. These engines do not overheat, even when crawling. Amazon has the DENSO ones for fairly cheap.
