A couple small updates:
I installed an UltraGauge a few weeks ago, I've been very happy with it.
I noticed my coolant temperature was a little high (it would run between 201F to 205F when warm). I did a little research and found that the instruction video I followed when I did my timing belt 18 months ago said to install the thermostat with the jiggle-valve in the 12 o'clock position (should be the 6 o'clock position). I made the change and now it runs between 190F and 194F when warm.
I also installed new headlight bulbs, I ordered PIAA 10704 Night Techs.
They are exactly what I want. Bright, not too bright, long lasting, and most importantly, NOT blue.
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s (
thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
