Originally Posted by Jetboy
My hunch is that CARB's emissions rules are not long for this world. If the EPA so desires it will strip California of its ability to have it's own emissions standards. - the whole supremacy clause thing. And it's looking more and more likely that the EPA will do just that. It may be reasonable to put the process on hold temporarily to see if the EPA revokes California's additional rules. IMO it's probably 70-80% likely that the EPA will eliminate CARB's additional rules.
Whatever the EPA does during the Chump administration can be undone shortly after the 2020 election, assuming Trump is ousted by his own party or replaced by a Democrat. Sooner if the House and Senate flip to the Democrat party in November.
I'd like to have more power at the low end too. Most of my driving is below 2500 rpm. Peak high speed power is fairly efficient now with the OEM system.
The hidden cost of this turbocharger system is the higher octane gas it requires. Here in California that 91 octane supreme gas costs about 20 cents more per gallon than regular. The price of gas is going back up. It's risen $1/gal in the past 12 months.
What happens to gas mileage with a supercharger/turbocharger? If you're getting more power and you need a higher output fuel pump, I assume you're using more gas per mile.
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
