Originally Posted by lossgenius
I have a 2000 4Runner Limited and just recently this behavior started. Going uphill the temp rises, I never let it overheat, I would pull over and let it cool off. It is fine driving on local/hwy roads.
Radiator is about a year old, thermostat was changed at about 170k (currently at 203K). I have a trans cooler to prevent the dreaded pink milkshake. There is no leaks, oil looks fine, fan clutch seems fine, no smoking and no loss of coolant (toyota red).
The thing that I find odd is when I turn it off to let it cool down, when I start it up I get the CEL. The code says the TPS is failing.
My question is, can the TPS cause overheating going uphill? I searched the forums and could not find anything regarding the TPS and overheating.
I may try changing the thermostat but wanted to ask for advice prior..
Thank you in advance.
I suggest another look at the fan clutch.
1985 pickup
: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5
: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited
: stock.
Build Thread YouTube Channel
