View Single Post
Old 06-28-2018, 09:34 PM
Battle Born Offroad Battle Born Offroad is offline
Battle Born Offroad has a spectacular aura about Battle Born Offroad has a spectacular aura about Battle Born Offroad has a spectacular aura about
Enkei RPT1 Offroad Wheels - Enkei is jumping into the Japanese SUV Offroad scence!
Were not sure if anyone else has noticed this, but does it seem like a lot of legendary tuner brands are jumping into the offroad market, particularity Toyota trucks and SUVs? Its great to see classic designs being adapted for offroad use.
Check out these awesome looking Enkei RPT1 Offroad Wheels - Only offered in 16x8 and 6x139.7, a perfect Toyota truck or SUV size! The Enkei RPT1 off-road wheel pays homage to the famous RPF1 wheel, by utilizing a similar twin-six-spoke style, while optimizing the design and sizing to make them perfect for Toyota truck use. Excellent strength analysis and design technology significantly improved the performance of their aluminum wheels by using Enkei's own MAT Flow Form Process with "knurling" to reduce tire slipping.
Enkei Japan Colors
Take advantage of this Enkei factory painted Japan-only color, which have never been introduced by Enkei on United States soil before. Previously only available in the Land of the Rising Sun, Enkei Japan painted each of these wheels alongside all of their other production wheels just for this batch. As an added relief, each color has been thoroughly tested, and approved by Enkei Japan’s strict quality control including rigorous salt spray tests.
What does that mean for you?
It means a tested, trusted, and treated finish unlike any other. Traditionally these wheels would need to be re-coated by a refinishing company to achieve these types of colors. Typically that means powder coating, which not only requires heating the wheel to a temperature that can compromise the integrity of the construction material, but also the finish is not tested or designed to outlast the elements.
Testing
Each of these wheels and its finish has been put through numerous salt spray and stress tests more rigorous than conventional standards. Enkei established its own test standard called “Spec-E,” which is tougher than JWL requirements. Enkei’s Spec-E test setting requires a higher drop point in the impact test and 20% more cycles for the rotary bending fatigue and dynamic radial fatigue tests than JWL standards. The Spec-E represents Enkei’s confidence in its technology and quality of Enkei wheels.
Part Number: 520-680-8400MDG
Bolt Pattern: 6x139.7
Offset: +0mm
Center Bore: 108.5
Finish: Matte Dark Gunmetallic
MAP: $381.72/wheel
Contact us via PM for a T4R members only price.
Battle Born Offroad is offline   Reply With QuoteReply With Quote
