Originally Posted by swapmeet
Hello, I've tried searching in a variety of ways and can't find an answer. So hopefully this isn't a wasted new post.
Decelerating/ braking creates a vibration in the Driveshaft or U-joint. My truck is a 07 4x4 V8 lifted 3.5+" on Radflo 2.5 shocks, which are very soft. Because of the softness, I get a lot of nose dive when braking, so I think it exacerbates the issue.
I've always had a minor vibration when accelerating hard, and still do. This feels similar, but much more exaggerated.
My thought is that its either pinion angle or the slip yolk. I remember people saying it helped to get a driveshaft spacer if you lifted your truck because of the slip yolk. Is this still a thing?
I'm looking at adjustable arms for the rear, but I don't want to pull the trigger until i'm sure it'll resolve my problem.
In case anyone feels compelled to ask, its not the brakes. 100% sure.
Thanks
Are you completely sure the vibration is in the driveshaft because I was getting a vibration on deceleration and coasting from about 40 down to 20 but went away in 4wd (indicates bad needle bearing) Maybe this helps
