Originally Posted by AuSeeker
NO, my first action would be to spray a little WD40 or other spray lubricant on the steering shaft U-joint to see if that is where your stiffness is coming from and the spraying it temporarily solves the issue, IMHO with you being in the rust/snow belt that is your issue, needs a new steering shaft.
Agreed. Had same issue a couple years ago and even bought a new shaft, but after a couple spray lubes it has been fine and 3 years later I still have the new shaft sitting on the shelf.
