View Single Post
Old 08-14-2018, 05:24 PM
emcdemc emcdemc is offline
emcdemc is on a distinguished road
Originally Posted by mag3 View Post
Hey all! Long time no type.
I am having the same issue in my 2006 4 Runner Ltd. In my case, the driver's front turn signal light. The rear left turn signal light is still functioning, and the right side has no issues at all (clicks regularly). I'm convinced the bulb needs replacing.
The question I have is, what's the best way to get to the receptacle? I know that, once reached, it's just a matter of turning the receptacle counter clockwise to pull it out and then replace the bulb. But how do you best get to it with the easiest effort? Wouldn't ya know.... the left (driver) side is the one where the battery is in the way. Ugghhh... Is it worth removing the battery temporarily to get at the light receptacle, or can the headlight assembly be removed more easily?
See the attached pics.
The main headlight assembly. The bulb to be replaced is the amber bulb on the upper right corner of the assembly (as you're viewing it). More about the brackets that appear above and below the assembly in a minute.
View behind the assembly. As you can see, the battery is in the way. I have seen some YT videos where the person took off the front left wheel well covering to get to it, but I don't know if that's worth the time and effort.
Side view. Please note the black fastener covers. Is there an easy way to pop these off without breaking them? Do they just lift with a flat screw driver or do you need some special tool to take them off? And will taking these off be enough to free the headlight assembly or are there other fasteners that need to be undone?
Upper View - Note the light gray bracket with the tabs. Do those need to come off? I hope not, because I've already broken one of them and don't want to break another.
Any advice, greatly appreciated.
Thanks!
You shouldn't need to remove anything. You can reach in and twist the bulb housing out of the slot.
emcdemc is offline   Reply With QuoteReply With Quote
