Originally Posted by jackjoachim
Ok one more question, Can I replace both the OEM studs from the wheel hub, and replace the spacer studs with arp studs?
yea but thats kind of expensive and overkill, and won't do anything to protect you if someone can't/won't follow directions (i.e. grease monkeys) on installations and tire rotations.
I'd only replace them if you HAD to replace them, as in you snapped a stud already which is quite common
