Real Name: Tony (no surprise)
I ended-up reaching Dustin over email, and he responded immediately. There are indeed two options. I was hoping for a hubcentric 106mm bore...
From Dustin:
We have two versions for your 4Runner:
Version 1
16x8" +0mm offset 6x139.7mm PCD (108mm center bore)
Includes metal push thru center caps with 108mm outside diameter and matching flange to the wheel chamfer and 106.2mm inside diameter to center the wheel on your hub.
We also include 108-106 hub centric rings in the event you do not want to use caps.
Version 2
16x8" -20mm offset 6x139.7mm PCD (106.2mm center bore - hub centric)
The wheels include flat snap-in center caps.
Due to the design of the 16x8" -20mm offset version (extremely deep lip and shallow hub along with hub centric center bore) you will not be able to use the center cap on the front wheels if you have a 4WD model, due to the factory axle cover height. The wheels will fit perfectly, but you'll just have to leave the caps off the front wheels.
2000 Limited, E-locker
Maintenance/Build Thread
