Originally Posted by Dropzone
helps to say what year 4runner you have, but no the window wiring doesn't usually run behind the radio. Hard to say what previous owners have hacked up though
does it work from the switch on your center console? both 1st and 2nd gens have the switch there. Did you remove the center console and run any speaker or amp wiring along the tunnel?
How were your fuses?
Is it possible you have the power window lock on? if so it won't roll down (not sure if that is true for using the key)
I have a 2000, but the power window lock is not turned on, and it works from the button in the center of the dash. The previous owner had it wired for subs and an amp but there was no wiring running along the tunnel. It’s not that big of a deal I was just wondering if the radio had anything to do with the radio.
