Originally Posted by jafrush
Hey, sorry I missed that one.
You just remove the factory battery mounting tray. Beneath that is a small sheet metal shelf the tray rests on. The cage has a hole pattern in the bottom, you simply pick a few of the holes, and either use supplied self tapping sheet metal screws, or drill and rivet the plate in place.
You will need to extend the factory battery leads by about 2" if using a group 31 battery.
Mine was super simple to install. Bought some Slee extenders and it went right in.
