Originally Posted by Inv4drZm
The grease is pretty much everywhere. The CV shaft, shock, and bump stop are all covered in crap, its just not fresh grease which could mean most of it has already leaked out. Removing the clip might be hard to do without cutting the boot in the process.
Reboot it if you want, but to me its more of a bandaid fix.
i didnt see any grease flicked about apart from the obvious black shine at the part that has moved. perhaps the op could double check for this grease the pics are not that clear.
a clip is not a band aid fix, if the shaft does not knock and has not lost grease, then it could be all thats required if the boot is ok.
