Originally Posted by GX4SEVEND
Little update.......bought the katana kit....one light fits perfect. Lines up perfect. The other does not. Switched sides. One light works fine. The other does not fit regardless of what you do. Will not for in the housing without getting stuck or having to pound it in. Should not be this difficult to install lights. I’m sure other kits from them have worked fine but this did not. Second kit I’ve bought and have spent $100 total and wasted time and effort into this for headlights.
So definitely purchase this kit with caution. Like I said, one fit perfect and was aligned perfect out of the box. The other doesn’t even fit at all.
Remove the Katana O ring and use your OEM halogen bulb O ring, i find OEM halogen O rings to be of higher quality and thinner to make non-OEM bulbs like LEDs fit better.
