Originally Posted by dade73
I have a Smittybilt X2O Procomp (both the 10k and 12k are same size)
Synthetic line, aluminum hawse fairlead. Fit the bumper just fine.
I did have to make a small notch in the lower end of the L bracket coming down in front of the radiator. This was due to the cross support bar on the winch.
I mounted my control box on the side vs the top. This allowed for much easier access to the on/off switch.
I also have a 20" led light bar in the bumper. Winch still has plenty of room.
Just a note* I found it easier to thread the rope through the fairlead, then attach it to the drum. set it remainder of the rope to the side. Installed the bumper. Power everything up. Then spool in your rope.
Can the stock hook on the SB x20 be swapped out for a Factor 55 flatlink? It looks permanently attached from the pictures?
