Originally Posted by nevada
unless im reading that wrong, the "actuator assembly" 47050-35030 lists everything, MC included for $1945. whereas JUST the MC is $1222.
a low pedal would likely be the MC bypassing internally. but you have to split both pieces apart to change that, makes sense to just change the entire thing at once. tons of these have had the booster portion fail though.
Correct that part does include both. I wasn't sure if getting separate was the way to go (if one of them doesn't fail as often as the other and it wasn't worth it). Good thing I have no interest in getting rid of this thing as this is an expensive repair.
