Originally Posted by ridetime
I've seen it. TBH I don't think it looks that good. Usually the chip still stands out because either the color doesn't match that good or the filled in chip is still below the level of the original paint. But if you want to take care a lot of chips at once, this is the easiest solution.
I've had better results with the factory touch up paint and layering it with a 1.0mm microbrush. If the surrounding chip has any high spots, you have to level it by scraping the chip with a razor.
