Originally Posted by Mtnman01
Thanks for the advice. I was rushing a little as I had purchased the marker lights and wanted to install them so thought get the switch (Switch Pro) setup and add a compressor. But like you point out maybe do the big mod first (dual battery) as that will dictate what happens next.
I'll stick to researching that for now. From the searching I have done it seems like a more stable mounting point is the passenger from (Shockworks). All the ones I see mounted at the back (passenger firewall) seem to have comments about been loose or not having confidence in the mount.
Go to my album and check out my dual battery mod or type in Keith PDX in the search window for his dual battery install that's where I got alot of info for my build. Also if you google "4runner dual battery mods" look at images and go from there. I used the shrockworks tray. but my 2011 did not have the air pump in the front tray area. but they make a kit that moves the pump to the fire wall. and still install a air compressor on top.
