Trying this again, take two..Sorry some pics are sideways, I'm not sure how to correct this.
Thank you Accessorides for making such an incredible product! All directions are taken directly from the extremely easy directions sent with this kit.
Accessorides remote starter!
G KEY
Remove the long driver sill panel that is only held by clips starting at the front.
Remove the plastic nut holding the kick panel on.
After you remove the kick panel which reveals a 10mm bolt that holds the driver underdash panel on.
On the right side of the driver underdash panel is a small hinge that covers another 10mm to remove.
Remove the small panel in front of the shifter which covers the right side of the underdash panel and left climate control knob. Panel pulls straight out towards the rear of the vehicle
Remove the underdash panel and unplug any connectors
