Thread: 5th Gen Install
View Single Post
Old 01-21-2019, 01:27 PM
Packr12's Avatar
Packr12 Packr12 is offline
Packr12 is on a distinguished road
Packr12's Avatar
Underdash panel removed.
Next remove the steering column shroud. Turn the steering wheel left and remove 1 screw straight in then turn the steering wheel right and remove the other screw. Then separate the 2 halves of the column and remove the lower portion.
FOR WHATEVER REASON I DON'T HAVE A PICTURE OF THIS STEP.
Make sure ignition is off before proceeding.
If your vehicle has an OEM hoodpin, cut this loop and isolate both ends. If your vehicle does NOT have an OEM hoodpin, leave the loop intact. CUT=with OEM hoodpin UNCUT= without
Locate OBD2 connector that you would plug a diagnostic tool into.
Unplug the OEM OBD plug and plug the new harness into it.
Then mount the other side of the new harness back into the OEM spot.
Locate the ignition switch harness under the ignition cylinder.
Unplug the OEM ignition plug.
Plug in the Acessorides harness. Be sure to telescope the wheel in/out and keep the harness away from any moving parts using the provided wire ties
2016 TE KDSS
Instagram @upstateoverland
Packr12 is offline   Reply With QuoteReply With Quote
